C cork Member Joined Apr 11, 2004 Dec 2, 2011 #1 What gasket is needed between the test pipe and exhaust y pipe? The test pipe is Terry Houston and it has a 4 bolt flange.
X xrunner123 Member Joined Oct 2, 2002 Dec 2, 2011 #2 Not sure if you need one if it's nice and flat. I never had one on mine.
TurboTGuy Gray Beard Member TurboBuick.Com Supporter! Joined Sep 24, 2010 Dec 2, 2011 #3 Don't have one on mine, only on the header type flange on the dump.
B buickruss Active Member Joined May 25, 2001 Dec 2, 2011 #4 Metal to Metal. Usually. I replaced my old rusted Y pipewith a used one that wouldnt seal properly. I cut a cork gasket and it has held for about 500 miles
D DOUGGN Member Joined May 17, 2011 Dec 2, 2011 #5 cork said: What gasket is needed between the test pipe and exhaust y pipe? The test pipe is Terry Houston and it has a 4 bolt flange. Click to expand... I actually have one of those gaskets from a test pipe - if you need it PM me. It's brand new.
