I've bought a TH400 rebuild kit that includes extra frictions and steels but I'm having a s**t of a time trying to get anything to fit. The vendor isn't that helpful, when he finally replies to emails, (he usually doesn't!) so I'm throwing this out to you guys for some advise.
I've been trying to go to 6 stack forward and direct packs but have pretty much given up. The direct drum is NOT the deep 6 element one so I've settled on 5 with the 0.0915 steels. It has 0.025" clearance right now. I've changed both pistons to alloy ones so I can machine them for the desired clearances.
How much should I shoot for? I'm guessing 0.050" or so but some publications say 0.030 to 0.040". Isn't that a tad too tight?
The forward has 5 with the 0.0775 steels and there doesn't seem to be a way to fit the extra one in here either unless I keep the clearance real tight. What clearance should I shoot for here? Again I've read 0.030 to 0.045 is ideal.
What's better in the forward pack? A 6 element pack with thin steels or a 5 with the thick steels? It's not a shifting clutch so it shouldn't get too hot? Right? But they seem too....
And finally the intermediate.... The vendor told me no machining or extra parts are required to fit the 4 element "power pack" in here either. I guess that if 0.003" clearance is cool then I don't have a problem!
This piston isn't square so will load one side the the pack before the others so I'll square it up and take about 0.030" off it doing so. Any more and I'll run into the center support snap ring. That should give me about 0.033". Still not enough. (0.070"?) I'm guessing the only way to make this fit is to swap out the backing plate with a thinner one but I've already spent more than I've allowed (client has already paid for the parts) so I can't get more parts shipped over here.
Can it be machined? It looks to be b***dy hard so it's going to be difficult (read that as expensive!) to do. It's about 0.436" thick at present.
Any suggestions?
Any suggestions?
