The reason yours doesn't work is because the brphotrods mounts place the engine farther towards the front and higher than other mounts. If the engine is mounted farther back, your current setup would probably work fine. I'm guessing you'll need some fabrication to make it work with the brphotrods mounts, but it should be easy and fast for the right fab guy.
