The difference between A TA49 and a TA33
BuickTV6
kicking butt Intercooled
Hey I was wondering what the difference between these 2 turbo's are? I heard they use the same compressor wheel? Do they produce the same cfm? and does it bolt right up loke a hotair turbo? I know theres a difference in the way it mends to the intake, but im running the TM Ic kit so the conpressor is reclocked like the ic'd cars.I might be able to get one for a good price and wanted to know how much different it is compared to the Ta33 i got. Thanks
regards
I don't know the differences right oof hand but I'd say the 49's housings are probably more efficient. But If I were you I'd get a bigger turbo then either as long as you don't mind changing to bigger injectors. My friend runs a 60 with his T/M V-3 intake and 40#er's.
