Daniel Jost
Squirtin six
- Oct 11, 2003
Okay all, I have come to the time that I would like to write an official Build thread for the MS3/X. The build I am going to cover is going to be the full out all the options build (Or near to it). There is still development going on with the MS3 swaps and my car is going back into storage since school is starting in 2 weeks but we have two others on this board that have built and installed MS3/X on their cars with great success. I have ~7,000 miles on my car this summer with MS3/X and not a single issue to date, With a road trip in the mix. This is a really fun project and does take some time, but when you are done you will know more about your Buick than you had ever imagined you could!
This will allow to these options and I may be missing some;
-Fine tuning for up to 44PSI Boost
-Plug and Play
-SFI and individual cylinder fuel trim
-No MAF
-Wideband A/F Correction during normal driving
-On the fly; tune switching (2 tunes), and ECM flashing
-Electronic Boost Control, w/launch boost control and launch boost timing
-2 Step and 3 step
-LSx Individual Coil Ignition and individual cylinder timing trim
-Ability to control Fuelab digital fuel pump for output control (or dual fuel pumps)
-Automatic VE table correction, using WB02
-Ability to use GM flex fuel sensor
-Lean Cruise
-Calculated MPG gauge
-EGT input for data logging and high EGT protection like de-rating, lower boost/timing
-Alcohol Control
-Nitrous Control
-about 12 extra Output control for just about anything
-About 6 extra input controls for anything
-Ability to run 12 High-Z injectors, for example bringing 6 in under boost.
-The ability to use any engine's electrical parts
-E85 or Gasoline
To start off with, What to buy?
A decent soldering station, ebay works great
(http://www.ebay.com/itm/Stahl-Tools...079471?hash=item4ad846826f:g:WG0AAOSwaNBUf1PY)
Make sure you tin the tip correctly and use the damp sponge to keep the tip wet, there are good tutorials on youtube so I will no cover it here.
Radio Shack:
-8oz. .032" solder from radio shack (64-009)
-Desoldering Braid (64-2090E)
DIYAUTOTUNE.COM
1-MS330-K MegaSquirt-III Engine Management System w/PCB3 - UnAssembled Kit DIYAutoTune.com (This can also be bought with a 44PSI MAP sensor instead of the 21PSI)
2-MS-Wirebund MegaSquirt Wiring Bundle - 23" Long DIYAutoTune.com
3-MS3X-SM_Bund 23" MegaSquirt Wiring Bundle for MS3X DIYAutoTune.com
4-DIYBOB-D56K DIYAutoTune.com
5-MS3Xpander MegaSquirt-III MS3X Expansion Card DIYAutoTune.com
6-MapDaddy4 MapDaddy 4 Bar MAP Sensor with Barometric Correction DIYAutoTune.com (This is not needed if you are not going over 21PSI, or if you ordered it with a 44PSI sensor in the kit)
7-Jimstim-c JimStim v1.5 MegaSquirt Stimulator with Wheel Simulator - Assembled DIYAutoTune.com
8-StimPower MegaSquirt Stimulator / DIYPNP Power Supply DIYAutoTune.com
Digikey.com
4N25 Optoisolator- Digi-Key - 160-1300-5-ND (Manufacturer - 4N25)
If you already don't have a good wideband-O2 you will need one also, I use a Innovate LC-1.
Reference Threads: I covered a lot in this thread on the build as well. and MS3EFI.com is a big helper.
http://www.turbobuick.com/forums/threads/going-megasquirt.333796/
Just follow the MS build manual located below, and the information I have attached for the cam and crank circuits. I'd attach my file for the exact hookup from the MS3/X to the adapter board but i don't feel comfortable doing so since I have modified the wiring a lot since i made them.
http://www.megamanual.com/ms2/V3assemble.htm
-Plug and Play
-No MAF
-2 Step and 3 step
-Lean Cruise
-Alcohol Control
-Nitrous Control
-E85 or Gasoline
Radio Shack:
DIYAUTOTUNE.COM
Digikey.com
