blackbuick87
Senior Member
- Mar 11, 2002
My regulator likes to gradually lower itself. I always run 45psi (Thrashers) and a while ago I started getting a little knock. I check the fp and its at 38psi
Reset it to 45psi, after about a month I checked it today and its at 40psi . The only reason I looked today is because I lost 3psi of boost, and found a split hose on the vacuum block.
So anyways I try to tighten it as much as possible without stripping something or bending the allen wrench. Anyone else notice this?
. The only reason I looked today is because I lost 3psi of boost, and found a split hose on the vacuum block. So anyways I try to tighten it as much as possible without stripping something or bending the allen wrench. Anyone else notice this?
