Throttle Body Flow #'s?
No one,huh?
Welll here's what I got today on the flow bench:
All testing was done:
1.IAC housings removed.
2.Vacuum blocks removed.
3.Level 10 on an SF1020[up to 1,000 cfm]
4.IAC and vacuum block openings duct taped shut to prevent errant readings.
5. 3" mounting pipe with rubber seal used for T-Body seal to unit.
A: The stocker[58mm]-this one came in at 535 cfm.
We ended up using a 3-2.5" header adaptor with flange to mate this one to the sealing surface[pipe up back end of T-Body].
The numbers may be a tad low on this one because of this.
B: Modified 65mm Accufab[sorry,I couldn't wait:D]
This one came in at 700 cfm.
I think it's got another 20-30 cfm in it,if I work it a *tad* more.
C:Stock 70mm Accufab[untouched].
This unit came in at 730 cfm.
Pretty good if you ask me,however we're going to have to do something about this one [sorry Bweavy:)].
I let you know where it winds up.
Later...The Radius Kid.:)
Not sure of where to find a link for the flow #'s John.But I'm dying to see what you did with my BGC intake & knock yourself out with my TB bud!If you get a chance shoot me some pics.
You're going to love it.
I don't have a digital camera available to me,so you'll just have to wait for B/G top see them.:)
