John Larkin
Sublime Master of Turbology
- May 25, 2001
I drove the car to work and found I had the boost set too low. I was getting 790 - 800 O2 and no knock at WOT 16psi. So I stopped and upped it to 20psi. Still getting same numbers on flat ground but alot more power obviously. Going up a hill on the way home, I floored it. It dropped into 2nd gear and my audible knock detector beeped, the knock gauge was all the way to red and I let out quickly. The scanmaster recall showed 812 O2, 5.6* KR at WOT 2nd gear, 20psi boost. I am not logging currently. I don't even know what the wideband was reading but it is usually 12:1 at WOT on the gas scale.
I think I should take out a little timing in the Turbotweak chip, maybe 1*?
Opinions appreciated. There is nothing banging up front but I did hear a clunk in the left rear of the car that I think is a body bushing possibly.
