I have not used your product but this part of your statement is not true. what about this system? it's the one I personally like due to the more stock appearing.BuickGn Boosted said:We are the only ones offering a complete setup from the turbo to the air filter
TurboIndian said:I have not used your product but this part of your statement is not true. what about this system? it's the one I personally like due to the more stock appearing.
http://www.psmbuick.com/products_coldair.asp
6GUN said:Axl,
Thanks for your positive feedback on the"TINMAN" Cold-air kit! Are you sure you didn't pop a "Viagra" before installing your kit?...... actually,your results are quite typical . Glad to hear you are happy with our product.
We manufacture the "TINMAN" Cold-air kits to be the best possible fit, quality and performance available, bar none. They have been designed and tested to outflow any other 4" kit on the market for the Turbo Buicks. The "TINMAN" Cold-air kit should be the last intake kit you'll need until your Buick is running into the 8's.
Rodman99999, you can see or order a "TINMAN" Cold-air intake by clicking here: www.modelman5.com/tinmancoldairkit.htm By the way, the price is now $189.00 . Haven't updated the website yet. Sorry.But remember, you get what you pay for ,and component costs have been constantly rising lately.
Antagon, the "TINMAN" kit doesn't use a rubber elbow like the big mouth kit. It uses 4" mandrel bent elbows that will fit without drilling holes or cutting the radiator support opening.. And it will allow you to keep your fuel vapor cannister in it's stock location too. It also includes a better filter than most other kits are using.
And DonnieShort, just for the record, the' TINMAN kit was designed back in the early 1990's. At the time, kits were custom made to order, and we didn't advertise them. In 1999 , the TINMAN Cold air intake kit was advertised on the web by myself, and my dealers. Just weeks later it was "copied" and others were advertising their kits as "TINMAN" copies. That includes the big mouth kit which used a similar approach to bringing in cool air, BUT IS NOT identical to the "TINMAN" kit. If you need more info, call me or E mail me.#'s are on my website. ..There IS a difference....And BTW , the TINMAN kit NEVER, I repeat, NEVER used flex or dryer hose. Always mandrel formed, rigid elbows.
The TINMAN Cold-air kits are made and marketed directly by "Tinman Performance Products Co.( a division of Tylko Metal Fab) in Sterling Heights, MI. Also available thru it's dealers across the country. WE also are now producing 3", 3 1/2" and 4" MAF pipes to work with or without the TINMAN kits going to the turbo, with any MAF sensor or without MAF.
OK I feel better now.
Axl, Thanks again, glad you liked the kit. Thanks for sharing your results and input on the TINMAN Cold-air kit !!!
Al.......aka The "Tinman"
87' GN ,factory stock longblock, TA-49 turbo, 10.93 sec. @ 123.8 mph
Antagon said:I'm just wondering how the hell the tinman kit gets a 4in HARD PIPE through there. Guess I'll fiddle with the car some more this weekend.
BuickGn Boosted said:Thank you for your support.
The rubber elbow going thru the radiator support will bump up against the headlight bucket and dimple it just a bit but if it is causing a major restriction he needs to just move the elbow over.
I've sold more than 500 of these so I must be doing something right. We are the only ones offering a complete setup from the turbo to the air filter if you also buy one of our MAF or inlet pipes. BTW, our plain aluminum BIG MOUTH kits are $150.
6GUN said:DonnieShort,
No disrespect taken.
Just remember, you can't judge a book by it's cover. Example: the filter used in the TINMAN Cold-air kit was flow bench tested against the same size K&N filter( which i used to use many years ago). Both were 4" neck by 9" long cone. The filter now used in the TINMAN kit out flowed the K&N BIG time. In fact it even outflowed a 4" X 12" long K&N. ( not to bash K&N, they make some decent filters).
The TINMAN kit uses hard elbows , mandrel bent to a propietary angle( not 90 deg.) to fit thru the rad. support opening WITHOUT CUTTING. And yes, if things aren't "just right" the elbows won't fit. But these will flow better than flex or a rubber elbow.( No flames intended)
With 35 years in the airflow design buisness, I've learned a few things regarding airflow.
Remember, I originally designed the "TINMAN" kit for my own GN. Not JUST to make a product "to sell". I wanted it to be the ultimate Cold air intake set up for our Turbo Buicks and am always looking for ways it can be improved upon.
And Axl, Thanks again for the referral. Word of mouth is the best salesman. Yes, Bruce @ Aggressive uses the "TINMAN" kit on his own TSE Winning 87GN & has run in the 9's at over 140 mph. He has literally sold and installed HUNDREDS of TINMAN kits over the last few years !! Go Bruce !
Take-Care
Al
87' GN , factory stock longblock, TA-49 turbo..........10.93sec. @123.8mph.
GNAsuka said:So lets say we want to replace our filter.....where might we find one of these nice "high flow" filters?
6GUN said:84GNwith87eng,
DonnieShort,
I'm not going to get into a competitor bashing contest here. I have flow tested the "TINMAN" intake kit as well as other kits. ......and I have yet to see a competitor offer any flow test info on their kits. BUT I will say that the "TINMAN "Kit buried the flow bench I used (bench's max capacity) @ approx. 1,300cfm at alot less than the " standard" 28" static pressure(water column), which means it will flow alot more. And 1,300 cfm is enuf to support approx. 850+ HP.
Al
