R Renthorin Lone Wolf Joined May 24, 2001 Apr 18, 2014 #1 Anyone know the TQ for the rear diff bolts? I was told 30ftlbs by a GM guy but want to clarify from a TR owner.
E earlbrown runs with scissors Joined May 26, 2001 Apr 18, 2014 #2 Probably more like 30 inch pounds. But I never torque those bolts (or use a gasket). 3/8th ratchet and a short extention... turn 'em down until they're 'tight'.
jpwalt1987 Well-Known Member Joined Nov 9, 2003 Apr 18, 2014 #3 Are you talking about the cover bolts or the bearing cap bolts that hold the carrier in? Posted from the TurboBuick.Com mobile app
N novaderrik Well-Known Member Joined May 12, 2004 Apr 19, 2014 #4 those are 5/16" bolts- anything more than about 20 ft lbs or so is begging them to break... just snug them down with a short handled 3/8" ratchet... if they leak, snug them a little more..
F Fast4Ward Well-Known Member Joined Mar 27, 2005 Apr 19, 2014 #5 per Earl ....done same 5x now ....been in her rear more than I like
R Renthorin Lone Wolf Joined May 24, 2001 Apr 20, 2014 #7 Drained the old fluid, cleaned things up, put on new cover (replacing TA Performance cover), and added 2 quarts of oil plus anti-chatter. No leaks and the grinding on sharp left turns is now gone
GNONYX Well-Known Member Joined Oct 16, 2009 Apr 20, 2014 #8 Just in case you need more info on bolts Torque Attachments TurboBuicks.com_Torque_Spec.pdf 299 KB · Views: 1,012
