For years, whenever I re-adjust the tps to a .42 volt idle, it always automatically showed 4.6 at WOT. I just took it out for a few logged runs at WOT and I could feel it wasn't doing it's normal thing so I checked the tps. Idle was right on at 4.2 but WOT was only 4.25. Can the tps be adjusted at the WOT end also? I always thought not. Alternatively I suspect some kind of throttle linkage problem. Checked for clearance under the pedal and it was fine. Throttle under the hood did not seem restricted either.
Probably unrelated but when I got home I noticed that the "recall" button on the scanmaster (which has always worked fine) makes the panel go blank. Anyone experience that?
