Tps Question
86,87 wont work with a 84-85 connector because it is pinned different and it wont work with a 84-85 t/b since it rotates in the opposite direction. If you have a 85 ecm with a 86-87 t/b and have the conn pinned to 86-87 specs it should work. Is this a hybrid.
im using a homemade js man. intake set up with my stock ecm.
what pins do i need to change for this to work with my ecm? if i remember correctly dont you just swap the outer pins?
thanks keith
