I'll have to get near a dyno, maybe Monday. What are you trying to figure out? Are you interested in 15 mph also? Maybe TurboJim is near a dyno this weekend
I am just trying to find a trigger point for my EGR simulator so it can trigger off TPS for emissions use.
Got a chip in the WE4 with no EGR in it, 55lb. inj., and I built a simple PWM controller to output 15% or 20% EGR to more easily pass NOX with it. Almost failed last test.
Other car I found an EGR chip for my Bosch injectors in that car.
Gonna try it with TPS set at .55 volts as a trigger.
Next question is what EGR is commanded at LV8 of 64?
In the stock BBKJ image at 25% LV8 the timing values start at 400 and goto 2400 in 200 increments then next is 2800 to 4800 in 400 RPM increments, here are the values starting at 400: 23,24,24,30,30,38,44,42,44,44,48,42,42,44,50,50,50.
