Track Times...........
PHANTASM
POWERED BY POVERTY
i just took the gn to the track.
conditions: 55*f windy 20mph head wind. car was stock suspension no front sway bar.
i ran consistently low 12's @ between 107-116 mph, 12.12 best
with only 14psi of boost (highest i seen on gauge)
60ft sucked bad most 2.10- 2.30 with a best of 1.90
i ran m/t street radials at 16psi
110 octane, car ran great and no problems. turbotweak chip was flawless.
do i have a solid 11.50 car??? would be happy if i could get that.
Why were you running 110 with only 14 pounds of boost?
Why the 2.0' w/ M/T's
You have an easy 11.50's car--you just have some other issues and turn up the boost--and your there.
put the 110 in for the track in anticipation of higher boost levels.
also last year blew head gaskets and am still afraid of doing that again.
the chip is a race chip from turbotweak.
i have a manual bleeder valve that i am going to mess with as well as a adj wastegate.
track prep was real bad and very inconsistant.
gonna go to a better track and get my mid 11 slip.:biggrin:
