Trans cooler lines
rmc
I may need to replace the transmission coolant lines. Looking at the bends it will be a pretty tight fit........
will I be able to replace them with motor in the car? are the prebent hardlines best or is there a flex line I can use for ease of insrallation?
A couple vender sell replacement lines,as does classic tube I believe. Not sure if a vender sells the flexible lines,i think most of the guys make thier own if they go that route. You can replce them with the engine in the car,a little tricky just got to go slow and not get frustrated. The top tranny connection can be a pain.
I did it with the motor installed, make sure they don't vibrate together and cause a leak.
Sent from my XT1254 using Tapatalk
