N northerngn Master Monkeywrench Joined Oct 8, 2006 Nov 20, 2012 #1 Anyone care to share known good numbers (settings) for a good "starting point"? -Dan
N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Nov 20, 2012 #2 What kind of gate?? spring in gate gate size? co2 or no co2? If the gate is too small it will spike everytime usually, in closed loop. You should try open loop 1st to set your boost. P=50 I=20 D=20
N northerngn Master Monkeywrench Joined Oct 8, 2006 Nov 20, 2012 #3 MY BAD..I guess my title was misleading I meant trans creep(if thats even what its called) These numbers... These are just the numbers that are in here not mine...looking for some real word numbers ESP the ones on the right side
