So I took the hybrid out for a drive, Just around the block. I have had no problems with it at all. Just the day before that did a 75ft burnout no problems.
So taking for a drive not even pounding on it. I wired up the manual od switch and got it to about 40 or so turned it on. I felt like it went in then out and then came to a stop and it locked up. I could start it in N and P. Soon as I get it running and drop it into r,1,2,3 Clunks and dies. The car moves like less than half a foot.
Now is it possible that the OD is permanently locked? I just put a 5 disk lock up vig in there with the pump assist tube ect. Harden stator, sunshell , kevlar 2nd gr band. I had no problems before untill I tried to hit the od switch. I am just about my wits end. If this is not a simple fix car will be sitting for very long time.
Any and all info would be great. I am open to any ideas.
Thanks for the help.
Chris
Chris
