jasonlachapelle
To Hold on High
- Feb 6, 2004
I had a transgo HD2 reprogramming kit installed in my stock 200-4-R. My T has a Pro Yank extreme LU 3400 converter. I realize this kit isn't favoured on this board, but I had a lot of success with their 4L60e HD2-C kit.
The car was shifting perfectly before the transgo kit with the stock D5 converter. Now, the car doesn't shift until about 4800 rpm at very light throttle, both for 1-2 and 2-3. It'll stay in 1st until approx 85 km/h and 2nd until approx 110 km/h. The light-throttle shifts are bone-jarringly harsh. So much so that I have stopped driving the car because I'm pretty sure it's going to start breaking parts. Also I can't get the car to shift into 4th. I took it up to +140 km/h and it was still in 3rd. Downshifts during no-throttle deceleration were so firm it almost seemed the car was going to nose over.
At moderate to high throttle (40% or more) the car seems to shift correctly (crisp, but not harsh) and at the correct speeds.
I contacted transgo tech support. They suggested perhaps the TV exhaust checkball wasn't removed. It is. They also said it is most likely an improperly adjusted TV cable. I followed the gnttype.org instructions, as well as the transgo tech support rep's instructions (which are pretty similar). It did help slightly. At the "gm recommended setting", at 0% throttle, there was about 1" of "slack" in the cable between the TB linkage and the ball at the end of the TV cable. I took out the slack using 2 zip-ties and it seemed to help reduce the shift/downshift firmness, but not the shift point.
Any suggestions about how to resolve this issue ? I can really live without the "install X's kit" type of reply. I have read enough of them during the search and will keep them in mind for my next build.
