Translator & LS1 MAF
Switches are set like so reading from left to right, On, On, On, Off. At WOT the TPS reads 4.60 volts. As RPMs increase at WOT the MAF readings increase with the RPMs but at over 5000 RPMs it only read 195 g/s. I am using a low timing Turbotweak chip. Translator is set to 10% rich at idle, and currently set to 6% rich at WOT. I have the Turbotweak chip set to full rich at WOT and still getting a small amount of knock in 2nd & 3rd gear. I am using Bluetop injectors and the stock turbo. Boost is set at 16 #'s. The idle BLMs are reading 142 which is why I have the translator set 10% rich. I was wondering if the low MAF reading was causing the lean condition. I am using a RJC power plate and have checked all around the intake area for vacuum leaks and can't find any. I have replaced most all of the vacuum hoses. I have a new Walbro 340 fuel pump and a Racetronix fuel pump hot wire kit. I am also using a new Acufab adjustable fuel pressure regulator. The fuel pressure is set at 41 psi. Maybe I should raise the fuel pressure and tune out some fuel with the translator and chip if my MAF is reading correctly? Any ideas?
