Transmission mounting on cross member?
1KWIKSIX
Looking for some help. Would anyone have some pictures / details on how the transmission mount fits on the cross member? 🤷‍♂️
Not sure if this helps any
Should be bolt on mount through mounting hole, nut on mount bolt, & then the two bolts through the mount into the trans.
Been a while but that feels right 😂.
Need the rubber ends for each frame ends. There is a pair on each side.
Thanks Gentlemen,
Appreciste your help.
I was really looking for info on how the HR Parts N Stuff tranny mount attached to the cross member & transmission tail
Thanks Gentlemen,
If memory serves me correctly there is a small amount of grinding you have to do on the curled lip of the exhaust hanger to allow the H&R spacer to line up with the bolts that go into the tranny.
I can send a pic but it won’t be till tomorrow cause I’m currently out of town.
Thanks , I already had the grinding done & HR mount installed . Removed the tranny for repairs & in the process the mount as well as cross member were removed . Since they are now separated I do t recall how they went back together , wanted to verify prior to installing tranny back into the car
