STAGE 1 2004R.
FEATURES:Brand new GM pump with hardened stator ,steel rings and .555 cnc machined boost valve,3 clutch overdrive pack,center support to ring gear roller bearing,Alto wide band,E4340 steel billet band anchor pin,E4340 steel billet shaft forward drum,billet aluminum servo assembly,rollerized rear lo support/low clutch housing,rollerized output ring gear.Dual feed direct clutch,Custom CK seperator plate,recalibrated BRF valve body(or custom set up for higher shifts points,with new 3/2 control valve mods.Sump extension with bottom feed filter pick up.In car tested before shipping.$1399.00
FULL BILLET STAGE 2 2004R.
FEATURES:All stage 1 items plus E4340 steel billet input shaft,E4340 steel billet reinforced overdrive carrier,E4340 steel billet reinforced overdrive ring gear,billet aluminum direct clutch piston.ROLLERIZED FORWARD AND DIRECT CLUTCH DRUMS.Custom 3/4 direct clutch pack w/.101 steels and grooved red graphite racing frictions.$1999.00
ADD A BILLET OUTPUT SHAFT FOR 299.00 ADD STAGE RIGHT BRAKE FOR 39.00.ADD A DEEP PAN SHEET METAL STYLE FOR 299.00.ELECTRIC TRANS VBRAKE FOR 399.00.FREE SHIPPING TO YOUR LOCAL YELLOW FREIGHT DEPOT,NO CORE CHARGE IF YOU SEND IN YOUR BRF VALVE BODY AND GOVERNOR.All units are built with original BRF valve body and governor.If you dont want to send it in add $299.00.If you dont need a BRF code we will not charge the $299.00 core charge and we will supply you with a wot shift point of 5800 to 6000 or 6200 to 6500 shift point set up at no charge.Can be made lower @ your request.
