I have installed scanmaster on my Tr and have seen as much as 20*KR. To remedy this I have installed a Walbro340 w/ hotwire, replaced the fuel filter, installed a afpr and set it to 40psi line off. I have done a couple of runs and I am still up getting 10* to 15* kr? Next I am doing a fuel tune up with plugs and wires. If this dosnt help what else should I check? Could a bad maf or o2 sensor cause this much knock? All this is happening @ 15psi? What can be making it knock so bad at stock psi levels?
I have also just installed a front mount and have noticed when i let off the gas and it sputters knock will register?
I also have/getting 009 injectors w/ thrasher 009 chips but I do not want to install them just to make my problems worse.
