TurboTnZ06 Go on red! Joined May 7, 2002 Jan 11, 2017 #1 Can I cruise around town if I remove my powerlogger? Ie, just run a stock MAF, stock ECM and my TT 6.1 chip? I won't go WOT, just enough to use the car if I had to?
E Eric Stage I TurboTweak Guy Joined May 25, 2001 Jan 11, 2017 #2 Yes. It only uses the powerlogger for the wideband input. You can turn off the wideband correction using the parameters if you want.
