Hooked T-Link up tonight and I was playing around with the idle settings...I set my minimum idle air screw back a little bit than where it was so i could get my tps 4.55+ at WOT
so i set the tps to .42 with the ignition key turned to on but not started...then i went WOT and it was 4.70 so it's all good right? well not really...
once i started the car the IAC counts jumped way the hell up to 90-110 at idle...now i know it's suppoed to be between 10-40 so i am more than double the limit...car seems to idle ok but why are the iac counts so high??? the tps is set correctly??? what gives?
