N newkid87GN Member Joined Jan 21, 2007 Dec 5, 2014 #1 Hey guys,Will the Garrett turbine housing from a ta49 fit a Precision 5857 turbo without any modifications?
1KWIKSIX Well-Known Member Joined Sep 29, 2007 Dec 5, 2014 #2 DBB or Journal Bearing 5857? Suggest you ask Brian aka Bison.
B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Dec 5, 2014 #4 Probably not if the precision was a cea. All use the garrett t3/t4 bearing housing dimensions and have the same flange. The ta49 is a stage 3 t31 high flow turbine. Usually 11 blades. Type of shaft bearing doesn't matter BPE2013@hotmail.com
N newkid87GN Member Joined Jan 21, 2007 Dec 6, 2014 #5 Its an older model non cea..Thank you for your input.
