Hey everyone, I was just reading an article in this month's GM hightech performance (Turbocharging 102: hot side, July 2011). At the end of the article they provided the math to figure out the estimated horsepower of your engine, taking into consideration turbo boost and such. I tried calculating the numbers and here's what I got:
Air flow rate:
=(cid x rpm x 0.5 x V.E) / 1728
=(231 x 6500 x 0.5 x 0.75) / 1728
= 325.8 cfm
Pressure ratio:
= (absolute pressure + boost pressure) / absolute pressure
= (14.7 + 20) / 14.7
=2.36
Turbocharged airflow rate:
=(airflow rate cfm x pressure ratio)
=(325.8 x 2.36)
= 768.9 cfm
cfm to lbs/min:
=(turbocharged airflow rate x 0.076)
=(768.9 x 0.076)
= 58.4 lbs/min
Overall engine power ESTIMATE:
(Average engine uses 1 lbs of air for every 10hp)
=(Turbocharged airflow rate in lbs/min x 10)
=(58.4 x 10)
=584hp
Therefore, my engine assuming a 75% V.E, running 20lbs of boost at 6500 rpm should make approx 584hp.
The article used an assumed V.E. of 85%, so based on that, my engine would produce 662.4 hp with 20 lbs at 6500 rpm.
Pretty Cool!!
I used this math on the compressor map for my Turbo I found on the Turbonetics website, and found that to reach these goals, my turbo falls within it's 70% efficiency. It's top efficiency is 78%, so I'm not far off. Looks like I made a good choice. (My turbo is the Cpte60)
I'm not really sure how to know what the V.E. of your engine would be. I guess the more free flowing (Heads, Cam, Intake etc.) the higher the V.E. I've heard most engines are close to the 75% mark.
Air flow rate:
= 325.8 cfm
Pressure ratio:
=2.36
=(325.8 x 2.36)
= 768.9 cfm
cfm to lbs/min:
=(768.9 x 0.076)
= 58.4 lbs/min
=(58.4 x 10)
=584hp
Pretty Cool!!
