Turbo and Injectors
Aegis
Im running a TE44 with 42lbs injectors and alcohol injection; I want to upgrade to a T60 turbo; Do I need to upgrade the injectors as well and if so to what?
Your best bet would be to go with 60's. They will give you plenty to grow into. Your only 3 tenths from the 10's anyway.
Hope this helps.
JB
Which converter do you run?
How much boost?
Are you looking to buy new or a used Turbo.
Do you know the current duty cycle of your injectors during your runs? If not how much fuel are you adding via the chip?
Its hard to say now but if you answer the above questions we can make better suggestions. You may want to do the 6262 billet wheel unit and some 60%s or 80's if you're looking to upgrade both. You've got it moving the mail as is!!
Unless you go to a 6076 or something newer there will be about nothing there with a te60. You would only be going from the to4e 60 trim to a 60-1. Same ex wheel. You have about exhausted the hot side where you are already. I'd look into something else
