Originally posted by turbo buicks
besides all the "WOW!" comments you would get whats the point of going to a twin turbo setup when there are so many good single setups out there now. most of the Supra guys convert to single from twins. im not trying to start anything but im just wondering why would you spend so much $$$ going to twins when it seems like for less $$$ you could have had a nice single setup? do twins spool up better but offer more flow than a bigger single turbo so a high stall converter woul not have to be used?
Originally posted by tracer
With the ability to go mafless with something like the ME-R wouldn't it make it easier to put a twin together? You wouldn't need to engineer anything on the inlet side of the turbo, so it would be headers, brackets and outlet pipes to the IC. Comments?
Seems Like each Turbo is fed from each bank,,but seems they come to a common outlet ,maybe that is nmot the case with the 410hp setup picturesOriginally posted by GNSCOTT
If I'm not mistaken, a Supra twin set up is not like ours. I beleive the two turbos are inline with each other and one helps spool the other and they both feed all 6 cylinders where with our cars each turbo feeds 3 cylinders. My guess is that the smaller tubo is just too much of a restriction, and makes it faster just to remove it and add 1 larg one. Problably why they have problems spooling and why alot of the fast guys need to use N02 to help spool it.
Originally posted by JayC
Project X pictures
Originally posted by Ted A.
Sure was a good idea. Probably too many parts for Tony to remember to pack in the box though.
Originally posted by TRiv
Twins on a stocker, well sort of, 1983 Indy pace car, 1983 twin turbo Riviera convertible with 4.1 litre stage 2 @ 410hp detuned to cruise the Indy track in the turns @ 130mph! If they only made these into production on the Rivs & GNs, and intercooled!
www.waynefi.homestead.com/files/turboad.jpg
Special features ........................ Electronic Water/Methanol injection system
