where did u get those breather assembly's for your valve covers? i have been looking but, those are sweet.
Thrlskr--I really like the color on the valve covers. I see in your above post that the color is silver vein. When i googled that it came up as a Caswellplating color--is that the same silver vein? The parts they had pictured did not look identical to your color. I have some parts i want to do, and would like to use that color.
Thanks,
Geoff
A few small loose ends to tie up after the chassis shop finishes up.
Hey Bill, tuned a car tonight with a 66MM turbo and hit 686 RWHP at 24#s on PUMP gas/ Alky!!!
sure your gonna wait to turn it up![]()
I need some clarification...The car in this build made that much HP or another GN with a 66MM made that much power. If another GN, details....
Another GN made that power. He will be posting about it later tonight
It is a 109 stock stroke,GN1 Head car
This car will make more than than if all comes together right.
Phil - Thanks for the kind words and I wish I could make the OK event. I used to have several Fords and always wanted a GN since they arrived in 87. I never envisioned or thought I would be able to build something like this...it has been a life dream come true.
Only regret is I should have put the cage in it from the start.
Was at the Otto's shop yesterday...finished my restoration/painting madness.
Frame/undercarriage is done front to back, shot the inner front fenders, plastic wheel wells w/ SEM trim, and tank.
Hopefully next set of pics will be the motor going in the car!![]()
NopeMiguel son's car?
Man what an undertaking! You truly have a first class ride.
Question: How do you like the fenderwells painted. Mine are currently stock and showing it's age.... and I just thought I would be stuck with them. Your's looks fantastic. I was just curious how they were holding up?
What color did you use on the fenderwells? Inner fenders? Frame? It all looks so good.
Wouldn't this car be THS legal?....... and for that matter TAI legal? Boy.... what a combo. My hat is off. This thing will be a beast!
