J jacksorroche New Member Joined Feb 24, 2003 Mar 2, 2005 #1 Are there any other cars that use the same upper radiator bracket as the 86/87 GN?
T turbofish38 Le Pétomane Joined Dec 3, 2002 Mar 3, 2005 #2 You can use the one from a 78-87 G-Body with the Olds V-8(gas and diesel) but you have to weld on the nut stands for the top fan shroud/AC line clamp bolts. Otherwise it is 86-87 TR only.
