I remember seeing this stuff on TV years ago. The details on it are at Aluminum Welding - Aluminum Repair - Aluminum Brazing - AluminumRepair.com. Basically, you use a propane torch and these rods to repair aluminum and other metals (with the correct rods). On my dad's boat, the skeg (which is aluminum) on the lower unit was damaged by a rock and it took out a 50 cent piece chunk of aluminum on the outside of the skeg half way up. I think the prop must have kicked a rock into it and snapped off a piece. The boat shop wants to remove the lower unit and send it away for repairs, which I imagine will be a LOT of money. I think this alumalloy can do it. I think I could just repair it with this stuff and grind it back to shape and then repaint the skeg.
Does anyone have experience with this stuff?
