JDSfastGN
- Jun 16, 2001
I am in the process of diagnosing my engines issues. After doing a leakdown and finding a hurt number 1 cylinder and a few iffy cylinders I am pulling the motor. But in the process of the leak down I found two damaged valve stems. What would cause this? I run Kmotion K750s at 1.75 installed height with stock rockers on a solid shaft. Could worn rockers cause this? Worn valve guides? I realize the stock rocker assembly isn't ideal for a roller cam with heavy springs but I didn't realize it would cause this. Thanks for the help.
