Lee Thompson
- May 24, 2001
Since most of you guys have much more experience with a 200R4 than I. I wounder if anyone has seen this before. I was going through a BR VB today and ran across these 2 things.
The spring was somewhere in the 1-2 shift valve stack up. It fell out when I turned the vb on edge to dump the bore. The spring is about .500 long and maybe a little over 1/4 in. in dia. Thightly wound. The plug looks like it has been drilled and tapped for since it didn't want to to unscrew. Didn't try very hard. I compared this vb to another BR and it does not have anything in the bore. Open to any and all input. Thanks
