zzzwilliams3200
- Apr 18, 2003
I have been having a problem with my dash volt light coming on from time to time while driving, scanmaster reads 12.0 volts when its on, and when its not on around 14 volts. I recently figured out that it was directly related to my neutral safety switch, if I jiggle the lock ring that rotates on the steering column then the volt light will go on and off. What exactly should I do next? I'm not sure where the neutral safety switch is but it sounds like that might be the problem right? Any help is appreciated.
