I've had this problem happen 2 times in a 3 month period, and I am hoping someone has some insight...
Something is apparently on the way out, but for some reason the "Batt" light is not detecting it (I have checked... it does light up during key on/engine off and durning starting.)
Both times, I am driving around town, and notice the turn signal flasher is slower than normal. No adverse engine behavior, but I notice things like that! Anyway, I cycle the ol ScanMaster to read the battery volts, and it is way low. 10.9 to 11.2! The battery light is NOT lit when this happens, either. Since the ScanMaster and the flasher both indicate the volts are falling off, this seems to confirm I have a real problem (But without blown fuses, it seems like whatever is wrong it is not a short.)
Now, the problem does "Go away" if I continue to drive. This last time the volts rose to 12.8, and once the battery was recharged, returned to a normal 13.7v.
This problem is intermittant, and is a rare event. When this happened last, I was running with the parking lights on (Dusk), the other time I had the headlights on (Night) and noticed they were dim as well.
Anyone have a thought or two? Alternator or voltage regulator dying? Both? Loose/bad connection at the 1 wire connector? What would cause this problem and NOT light up the battery lamp?
The longest time I have experienced this is 5 minutes, then it recovers.
Please let me know if you have an idea!
