dennis1993
- Sep 26, 2007
hello all i recently purchesed a 1987 turbo t last october drove it a bit then put it to sleep til last month. over the coarse i changed to 60lb injectors, new fp regulator, walbro pump with hw kit ,tt alky chip, razors alky kit, new scanmaster 2.1 and powerlogger just to give you a basic idea of some mods. ok problem is at idle voltage at back of alternator is 14v scanmaster shows 12 to 13v set boost to 19lbs chip burned for 24 to 25 started to log some runs at wot and lo and behold the voltage drops to 11.2 to 11.8v then knock? checked all grounds tight and good
if anyone has any ideas i would GREATLY appreciate the advice! thank you in advance<
Dennis
Dennis
