Hi guys. The last month or so I have been noticing that my Ttype is "acting up" so to speak. Just FYI, its pretty much stock with the exception of a fuel system, blue tops, 2 3/4" DP, K&N, free mods, Thrasher 92 (dont like it, but its all I got right now). It has 118K miles and is in fairly decent tune. Original timing chain, and valve springs though.
Heres the description of the "problem":
The car usually has decent vac at idle....15-17ish. And when in gear it used to be 12-13. The last few weeks or so, I have noticed that when I put the car in gear, the vac goes to 10, then drops down to 5 or so and the car is struggling to stay running. I usually tap the gas pedal to keep the vac up, even though the car has never stalled out on me. So coming up to a stop light, the car is almost stopped, and it does the same, BUT not all the time??? Sometimes when stopped at a light in gear, the vac will be 10, sometimes 12-13??? Its odd. FYI, tps is .42, LV8 is 30-40, IAC is 10-20, and of course BLMs and INT are 128 at idle because of the thrasher. Oh yeah, car runs great at WOT....18psi in 1st and 2nd gear, drops to 16psi in 3rd because of the chip. Highest EGT reading I saw in 3rd gear was 1589*, BUT GET THIS, my spark plugs are always WHITE when I change them???????
So I swapped chips today. I put the Jay Carter 93 from my GN in the T-type. And now it just plain doesnt want to idle worth a crap. Vac is like 8-10, and I gotta rev it every now and then. But with the JC chip, I can look at BLMs now, and they are 141+ at idle, in gear or not in gear. I tried adding more fuel, but it didnt help. So its lean as hell at idle, and even driving around town???? But why is it noticable better with the Thrasher? Because of the open loop idle? Should I reset the IAC/tps again? I need to just quit being cheap and geta good chip burned for my car, but for now this Thrasher has to do......I guess.
I know this is a lot of blabbering, but Id really like to know why my car would "struggle" to idle, with relatively low vac, but still have good IAC and LV8 numbers. Ive seen the IAC as low as 04 at idle, in park. Ive seen the LV8 as low as 30, and Ive heard 35-40 is a good number. There is no tip in stumbles, no coughing, no sputtering at all. It just doesnt like being put into gear, or coming up to stop lights???????? I appreciate anyone who takes the time to read this........please let me know what you guys think. As always, THANK YOU
