Need help diagnosing this noise i heard when i got back form the gathering last Sat. It sounds like almost like a knocking fron the valvetrain i put a stethescope on it and it was pretty noticeable so i pulled the valvecovers and looked at everything and looked pretty normal. I rotated the engine with the started and all the valve moved the same amount. well my nest thought was maybe somthing on the bottom end so i figured drop the pan anc check it out. For grins i decided to disconnect converter and start it, no noise. trying to figure what in the trans would cause this only thing i could think is the pump. trans is about 6 mon old btw had it don by Len. any ideas? TIA
dale
dale
