was messing with the car awhile ago i undid the actuator to give it a couple cranks on the rod its been a bit cooler in miami so i wanted to feel some boost i took her out and got on the car and car went absolutely crazy i got off the throttle never felt the car spool so fast and pull so hard before...of course i wanted to give it another shot but stay on it and not let off....i get on the car car goes crazy again im trying to control her but shes laughing at the road..so far everything fine till i take a glance at my boost gauge needle is laying down behind the 30 psi mark, no knock must have gotten lucky since i always turn up the meth injection a bit while raising boost then ill gradually turn it down..anyways i let off the throttle and then the car blew the turbo to intercooler hose it ripped it apart.. made like a slit like it couldnt hold the pressure.... then i noticed i never connected the actuator line to the turbo when i put back the actuator...car runs fine no problem..but how much boost do you think this bitch ingested? i have a 3 bar map on it, gauge reads only to 30 psi..and i layed the needle under 30.
