Everytime I boost up at 12psi and up it cuts out. I changed the MAP sensor, checked the plugs, checked for vacuum leaks, new coil pack, what other kind of sensor or line could cause a miss that is boost related. It drive perfect to 12psi and spools quick but will then cut out and has a hard time getting above 15psi. Thanks for any help.
