What do you guys use?? Tial, HKS, Turbonetics(Racegate, Delta, evolution) Innovative(Pro, indy, mini)
I am thinking of using Innovatives Minigate.
Your thoughts, comments....ect
If you are looking for an external gate, the best one out there is the HKS GT gate. There are many people running them with great success. Norbs runs one. The only problem that he had was the spring was not strong enough to hold the gate closed from all of the backpressure in the exhaust. It is now fixed.
I sell the GT gate for $525. You can get a number of different rates, but it looks like you want the heavy (24.2 psi - 29.9 psi) spring. The only down side to getting the heavy spring is that you will not be able to turn the boost down to less than 24 psig.
car i just bought has two delta gates, 10.43@129 mph. used to be DEL's car. i'll see how they work out, i've personally always ran terry houstons down pipes with no problems up to 30 psi.
The days of turning the rod is over. I just enter my boost number and I'm done with it. I just had my Racegate right before the turbo flange and plumbed the exhaust back into downpipe.
