george harris
- Jun 4, 2012
Hypertech chip. Not stock. Get a Baily or Turbotweak chip for your comboHere is a pic, not sure if it is stock or not.
Hypertech, is that a old chip or used for a certain set up?Hypertech chip. Not stock. Get a Baily or Turbotweak chip for your combo
Does the car run good? Does it stumble when you first push the gas pedal?Hypertech, is that a old chip or used for a certain set up?
If I ease on it, it is good. If I go wot it stumbles and backfires.Does the car run good? Does it stumble when you first push the gas pedal?
The fuel pump went out last week, I believe it has a hot wire kit. I seen a connection on the back of the alternator. I do not have a stock chip, I have replace the plugs and wires already. So I am looking at getting a new pump and chip this coming week. I also have a 160 stat in it. So the best chip for this set up is the Turbo tweak? I am not sure if the injectors have been changed, but I have a cotton intercooler according to the tag.No chip should backfire. So you probably need to do some basic troubleshooting.
Fuel pump? Wastegate hoses? Boost Gauge? Spark plug wires? do you have a stock chip you can put back in for testing?
I agree that the Hypertech is stone-age compared to todays stuff for these cars. So plan on an upgrade there.
Post some more info on the car, pics, we can help you thru the troubleshooting.
Bob
The stock gauge, I will take some pics tomorrow and then post.....post some pics, most of our questions can be answered by looking at what you have.
do you have a boost gauge?
Bob
I have a scan master, I will check the waste gate hose.the wastegate control hoses (a y-shaped arrangement connected to the solenoid on the passenger valve cover) gets bad from heat and age. You should plan to replace it. It is most likely causing overboost, which breaks things.... (this may be the source of your backfire)
find it and see what kind of shape its in.
do you have access to a scantool that can scan the ECM for data and codes?
Bob
