SCOOBY DOO
BASED CANADIAN PATRIOT!!
- Feb 18, 2007
Either will end up making you have a bad day.
OH yeah I know that much!Either will end up making you have a bad day.
you didnt send me off my rockeri love eating hellcats,most dont hook on the street too well.you will have to upgrade the car a bit.the search function can be your friend,but in a nutshell,openened motor=valve springs,bigger turbo,injectors,fuel pump,trans/converter,drag radials,tt chip 5.7,proper scanning/tuning equipment.that will with a good launch keep the cats off you for a while till they are rollingnow kiss combo,and the cats will be coming up quickly=unopened motor stock turbo converter/trans,injector,basically leaving everything stock you can go real fast on the stock stuff with a shift kit/trans cooler,drag radials,255/340 pump,hotwire or kenny bell boosta pump,5.7 chip,scanmaster,dump tube or upgraded exhaust.the stock turbo can make 30psi it had its tungue out about 25psi but we ran 11s with the kiss combo above at full weight single nozzle alky with mostly stock parts including springs/timing chain and stock injectors it was alot fun and not much drama.the boys just want you to upgrade certain things and learn the car.Forget the hellcat thing, Sorry I mentioned it as it sent some of these guys off their rockers!..Im just looking for a little more power and speed and Im pretty sure my stock turbo is only pushing 12 pounds.
this is great
Steve's site kicks ass!this is great
Just read some of it thank you..this is great
So Walbro 255lb with hotwire Im assuming? Also who do you recommend getting the gears and chain from? I just seen the GM gears and the one gear looks like plastic!340 MAY require a larger return line. A 255 and alky will take you a long way. Cheaping out on a fuel pump is a big mistake. Deny these engines of fuel...and you'll end up in a world of hurt.
eric should have pump and hot eire kit since your geting a chip
Thanks I just seen them on Gbody parts..roll master is usually carried by most of our supporting vendors... i have my favorites but thats another topic ..
