What should the ohm outputs be???
'71buickg.s.
I had a moddified ECM burn up.
Bruce said:The best answer, would be taking an ohm meter, and going thur the outputs to make sure one wasn't too low, and overloading the ecm.
Can someone tell me what the ohm outputs should be for low impedience injectors? (#83 r's). I don't know enough to be able to do the checking myself, but a friend should I need to know what each of the ECM outputs should be so we know what's low.
Any help would be greatly appreciated.
Marty
[QUOTE='71buickg.s.]I had a moddified ECM burn up.
Marty[/QUOTE]
Marty,
I believe they (83#'s) are Spec'd at 2.35 ohms....but I guess if you get 2-3 ohms their in the Ballpark.
Joe
