Drewster
Wish I Had A Clone. AKA Andrew Youlio
- May 31, 2001
would like to fix, replace my exhaust housing.....
i tried to remove the turbine housing from the center section tonight. i was able to get the housing to spin freely on the center but it wouldnt separate. I finally looked inside to see what looks like the housing or a plate directly behind the turbine wheel. so i dont understand how the trubine wheel is supposed to pass through the housing hole if the housing is smaller than the turbine wheel. it actually looks like the wheel was fixed on the shaft after the housing was bolted up.
i would really like to remove the housing so i can fix broken bolts or replace the housing. i dont know if i will be able to. this may be a modified rebuilt turbo.
any tips or answers? heres a video to help explain. i am holding the compressor steady, ya can see best on a PC screen.
Drew
Drew
