What's my cam?
Sinister CO
My engine was built by Conley back in the day. I thought I had the stats on the cam at one point but if I did I can't find them. All I know is it's listed as a 276/276. Anyone know the specs on that guy?
That's probably the advertised duration.
With a 1.65 rocker would be .455" lift on intake and exhaust. Mild cam, I would assume your engine is iron headed?
Maybe Bison will have a better idea. He'll be around shortly. Those old timers know their stuff, just don't tell them I called them "old timers".
It's about impossible to come to any conclusion without any real data. Measure the lobe lift off a pushrod with a dial indicator.
did you just take 276 and multiply by rocker ratio to get gross lift? ...it doesn't work like that ..276 is in degrees not a measurement of inches
here's a 221/221 flat tappet cam card (.006" lift at 276/276 degrees ) that could be what he has but there's no guarantees
You take lobe lift and multiply it by rocker ratio.
On the cam card it shows specs with a 1.55 stock ratio. 1.55 x .319 = .494 and with 1.65 x .319 =.526
I was thinking .276" could have been lobe lift not degrees, not sure why I said "duration". I didn't have that card in front of me either. But either way (y)
Understandable as you had limited information.
I only used the cam card as the example to show how to find the lobe lift. The other way is to measure pushrod or the lifter travel with a micrometer as Bison said.
That way you can at least find the lift of the cam you have without pulling it out of the motor.
