87 turbo t , ported heads,ported manifold,206 cam, TH down pipe,forged pistons, 3 inch single exhaust, poston headers and crossover, 009 injectors,2800 converter,Lubrant chip,hotwire,arp head and main,billet main caps,power plate,breathers,scanmaster,boost and knock gauges,K&N 9 inch,balanced and blue printed. stock turbo and intercooler till I get some more cash!!
your combo is screaming for a turbo around the size of a pte 54-
it flows a little more than the te44 and spools just as fast, good to see you have a 2800 stall convertor-
if its still laggy, then get a trans brake-
that 54 with 24 psi and a race chip and race gas your car would run really well-
you can take the stock turbo up to around 21-23 as everyone says, but if you get alky, or propane it really helps get rid of the heat the stock turbos create at that higher boost level-
HTH
EDIT- make sure you order the turbo, {where ever you end up getting it from}
with the pte exhaust housing-
ps- if you buy it new, you get a warranty
