well this is the biggest turbo set up i have dealt with and i am having troubles reaching my goal of 11.70.this is a hot air car with a front mount I/C
1st heres what i have done, coated forged pistons, moly rings, line honed block w/ main studs installed,resized rods w/ arp rod bolts installed, balanced rotating assy,208/208 hyd flat tappet cam,home made js man. hot air intake kit w/ proted lower(port matched to felpro 1201 intake set,heads ported(bowls blended,port matched to felpro 1201 intake set),block is decked .015,hv oil pump, billet double roller t/c,009 42.5# injectors,limit TE-60 turbo, front mount ic,custom mad cold air kit,3000 stall, turbo tweak hot air chip.
launch at 15psi and about 2750rpm 2.64 60' 13.94 @ 97mph is the best i can get from this thing
any ideas or suggestions?
