where do I get those fuel line donut rings?
volvoman
The Green BEAST
I went to Shucks and Napa, are these fuel line seals hard to find or are they dealer only. If you guys have a part # that would be great. I need the fuel line gaskets on the feed side and return of the fuel rail. I also open to other kinds just as long as they are gas safe. The lady at napa tried to give me plane rubber seals.. Leak Leak .. I did not use them , good thing. Any info would be great.
Chris
local gm dealer will have a pile of em on the shelf.the same sizes are used on lots of years on lots of cars.
I give up
I called the dealer.
I say " I need fuel line gaskets for a 87 3.8ltr Buick Grand National turbo"
He says" "what model is that?"
I should have figured because before, I called and the guys asked me if a Grand National was a turbo?!!
:confused:
Then the only thing he could say is
"I am not showing a part # for it".
About that time I was :mad: He then says
" I don't really know anything about buicks.."
So I say
" you should , you are really missing out."
I really wanted to tell him that anyone that works at the parts counter at a Buick dealership should at least know what models of Buicks there are.
Oh and to put the fuel on the fire he says
" Grand National that sounds familiar, I have heard that somewhere before"
:confused:
So with that I will try to stay away from there unless I have a part #.
Do any of you guys have part # for the fuel line gaskets? The guy could not find any at all.
Let me know any info you have.. Sorry about the rant.
Chris
:D
TAKE YOUR PICK!
GM PART NUMBERS:
Fuel Injector 'O' Ring 10031124
Fuel Line 'O' Rings Return line at FPR 22516256
Fuel Line 'O' Rings Feed line at fuel rail 22514722
HTH
Here are some Borg-Warner p/n's (Autozone / O'Reilly's)
Injector o-rings (same as big o-ring on FP Regulator to rail) 274081
Fuel rail inlet and small FPR return (on bottom of regulator) as a set. 27478
John
I called Autozone, the part # where not the same but They still worked. Now I can finish my fuel lines. Is there a part # list that I can look up on the web in the future? You guys saved me from running around with my head cut off.
Thanks again
Chris.
:D :D :D :)
Autozoned out
So I go down there. And give them the # that they gave me prices and all. They say sorry dealer only.
I went to one other place. the guy says ac delco fuel line seal kit, $6 and AC delco fuel rail kit. $8 I just wish I could order GN gaskets and stock seals from one vendor. It would save me all this trouble.. So the guy ordered the pars, and I will see if its the right seal kit or not tomorrow..
Chris. :|
