bayareaturbo
- Sep 25, 2004
I was under the hood yesterday all my vacuum line's are cracked/falling apart and in need of replacing. Where should I buy the vacuum lines? Does anyone sell a kit? Thanks
I got good silicon line
+1
We did an experiment at one of our Club meets with reg vac line, what we were doing was jumping sparks across the vac lines to show that they can arc.
Buy Silicone
Me and my buddy tested some too. We lit both lines on fire, the silicon took along time to start to burn, the reg line went up in no time.
Thanks guys silicon it is. What sizes should I get if I'm going to replace every piece or how many feet would cover the job?
I searched and found nothing.Someone had posted the sizes and lengths before, but i'm not sure if it was on here or Gnttype.org.
Cruise Control Servo
Large port 9/32"
Small port 7/32"
Vacuum ball 7/32"
Washer Resevoir 8/32"
Washer Nozzles 7/32"
Charcoal Canister
To Tank 10/32"
Solenoid 8/32"
EGR to Solenoid 5/32"
Vacuum to EGR Solenoid/Check Valve for HVAC/Cruise 9/32"
Brake Booster 3/8" (9-9.5mm)
AFR 6.5/32"
Vacuum Block
3 ports 8/32"
1 port 6/32"
1 port 12/32"
PCV 12/32"
Wastegate Y-hose 8/32"
Total Lengths For Car
4mm = 122"
6mm = 147"
8mm = 46.5"
